Hello Peter, it is a torsional differential of wavetrack from USA. 2 years ago there was a collect order in the german cliors.de forum. but I would like to exchange this this winter against a Drexler diff
No, I have no interest at all, as opposed to here in Germany is not so common.Have you thought about fitting a Megane turbo engine rather than another Clio one?
KW ClubsportWhich KW coilovers are you running? That car was very composed on track. Good drive![]()
Sure, I do not know since I have no memories of the accident, the SD card was apparently stolen by someone from the camera. The accident happened after a long closing and I was one of the first on the track I think the tires were just too cold at the rear!Awesome car! Can I gave a go?! How did the crash happen with the 200?
yeah, i knew about the group buy on the german clio forum. i sometimes have a peek over there. i even bought some brake pads in the forum shop, a couple of years back.
you're not satisfied with the wavetrac?
So wavetrac has no pre load? I thougt that torsen diffs work fine. What's your experience from oem To waverrac? And where are you looking for?
K | Clio 3 RS F1 Team R27 Meglio - it will be a trackcar | Clio 197 Area | 72 | |
Suj's Nimbus Clio 197 and E36 328i Trackcar | Projects/Progress Threads | 438 |
