burrellbloke
I had two excellent track days at Croft and Donington recently. I took my track wheels which were a set of 17" Oz Ultraleggeras which had part work Direzza DZ03Gs on them. The tyres are 215 45 R17. The tyres had about 3 to 4mm on each tyre. I don't know what usage the tyres had had before I got them but they seemed to have fairly even wear across the tyres. I picked them up for a bargain £200.
Croft has a lot of right hand turns, as does Donington.
After finishing Croft the front passenger tyre had worn considerably on the shoulder of the tyre and it had sorted to delaminate. I originally put that down to aggressive driving, a bit of kerb smashing, and the car having a mild Gripper that was putting new strains on the tyres that had not been there before.
For Donington we swapped the wheel from the front passenger side to the rear passenger side. At the end of the day at Donington we had the same wear/damage to the front passenger tyre. Donington involved a lot of right turns and a lot of kerb smashing.
I have not really kept an eye on tyre pressures, but when they have been checked the pressure is usually about 30 hot. Should I be running the tyres at a higher pressure so that they have a stiffer tyre wall? Would that slow down the wear on the outside edge/shoulder of the tyre.
Also, the car is usually quite heavy as it has @EthanMenace and me in the car at track days. Does the extra weight need to be accounted for with tyre pressures - if so should it be higher or lower?
