TL4 gearbox....no not another broken one this time (gearbox stripped down)
Foxspeed
"the new red baron"
Moderator
got a spare box so decided to strip this afternoon!
not many tools required just a bit fiddly and i didnt strip the main shaft down as it would need pullers and a press - just curious over what type of chocolate they use on the synchro hubs/baulk rings
pictures to follow :clap:
tools used so far...
internals
reverse idler
mainshaft and layshaft
diff and mainshaft
view of baulk rings (brass coloured items)
selectors for 3/4 5/6 and the barrel selector
Great work there Foxspeed, which one(s) is/are the dodgy bit(s) then??
the brass coloured items are part of the issue - will try to get better pictures later on when i put it back together
must say this box is in very good condition - no chipped teeth/worn bearings/excessive metal swarf...
I see, how long did it take you to strip everything apart? Well at least now I know who is going to fit an LSD in my box!!
(joking:smile:)
nice work foxy, i think its the oil rather than anything else.
If you want I can bring my big camera around to take some hi-res shots, I'd be interested to take a peek too :wink:
fine tom - might start puting it back together soon - just need to clean/degrease the outer casings first
(joking:smile:)
it took me longer working out how it came apart - i didnt have any manuals so sort of guessed/experience sort of way to strip it :oops:
to get it to that stage about hour - to strip down the mainshafts would take alot longer as bearings need to be pulled and pressed off - but didnt use any "special tools" to get it in that state!
Excellent work mate, thumbs up. I would've been lost in all those gears, bolts, screws etc within 3 seconds...
I bet i'll be harder to put it back together!
Its that "O Sh#t" moment when you get it all back together and find a spare cog on your bench.....
Then again at least with 4th gear missing it won't crunch anymore.. Lol
worst part is the mainshaft-layshaft-reverse idler you have to sort of jiggle around to get them to all line up and the 2 selector fork shafts to drop in position....
still easier than the spicer boxes i had to strip and rebuild as they need to be timed :oops:
a few thoughts
early 06 and 56 plate gearboxes seem to be better/more robust?
i have a parts listing from a dealer showing that 1st and 2nd gear have a 3-part synchro hub/baulk ring arrangement - i thought that the 3-part items were on 3rd and 4th...
i wonder if the 2007/8 boxes were changed to 3-part on 3 & 4 and this was their down fall?
will have a closer look at the stripped box and see what it has!
as for oil - theres a clever oil collector in the gearbox casing that collects oil spashed from the gears that feeds one of the mainshaft bearings - could be an issue if the gearbox oil level was low...
anyone have any other info on the tl4 box?
