suj
Hi all,
So my thermostat looks like it's going, sticking open (overcooling).
So I have done a search on here and found the following threads:
http://www.clio197.net/threads/changing-coolant-thermostat.55802/
http://www.clio197.net/threads/thermostat-change-and-coolant-system-bleed.52567/#post-580155
So a summary:
* 2 bleed points
- Heater matrix pipe
- Thermostat housing
* Heater on full temp (autoclimate, so 27 degrees) when cooling (normal for cars, so this is fine)
* OEM Renault coolant is a yellowy/green colour.
* Don't mix coolant colours (always made sure I put same back in anyway on other cars)
* Part number of Thermostat is 8200772994
So a few questions, is there any tips to do it (just many cars have different ways, like my MR2 was park nose down etc)?
Is this correct:
- Remove the housing pipe, lift up so you don't lose too much coolant
- Open the bleed points when refilling coolant
- Keep open the bleed points with engine running to allow air out until coolant comes out
- Let it cool down and top up the coolant level
Also my car has pinkish red coolant, so what can people suggest to put in? (It had cambelt etc done at ALS by last owner, so they put it in, I guess I can contact them and find out).
Also I would like to do it ASAP, ideally a genuine Thermostat, but seems like it is too late to get one soon (don't really want to run an overcooling car too much), anyone who where I could get one ASAP, or any other aftermarket ones people suggest?
I don't get Good Friday off, we get Monday and Tuesday off, so I have Tuesday to do it if needs be, but I would like to do it Sunday, get it sorted.
Thanks in advance.
So a summary:
* 2 bleed points
Is this correct:
Thanks in advance.
