Ok so I have just had some H&R lowering springs fitted and now have a knock from the offside front at low speed over repeated harsh bumps (worse when turning into a corner with some lock). Doesn't make a noise when going over speedbumps or at speed.
There was a slight noise when dropping off the drive before so the springs may have made this worse.
What should I be looking at first?
To remove the springs only the droplink and topmount where removed and all off these where checked after we found the knock and everything is tight?
Sam
Sam
