Hi all,
Hoping you can help. I recently had front pads changed onto old discs (Brembo pads) a few months later I changed discs and then pads. (Brembo HC discs and PBS pads) regular braking has always been fine. Gradually I have started noticing a weird pedal feel however. When I brake quickly and slightly aggressively the feel from the pedal is like something is slipping or catching, but its very specific to the pedal or components attached to it.
This might be ABS kicking in but it feels different to other cars and Id have said its not enough to lock up the wheels.
Could this be the brake master cylinder failing? I have no idea if its ever been replaced but the car is now on 124k.
Thanks in advance!
Thanks in advance!
