Steering uj HELP
Discussion in 'Clio 197 Area' started by Bro, May 16, 2019 at 8:29 PM.
  1. Bro
    Bro Paid Member
    18
    Car:
    Clio 197
    Hello all
    Took the subframe off to repair the manifold and now when trying to get it back on the uj just wont go back on the shaft. Tried everything if anyone can give me some advice I'd appreciate it
  2. GazMav
    GazMav Paid Member
    39
    Car:
    Daily 197, Track Meglio
    There is a two flat sides you have to line these up then the bolt goes through.
  3. Bro
    Bro Paid Member
    18
    Car:
    Clio 197
    I've been lining the two flat spots up but it still seems like the gap is too small for the shaft to fit
  4. GazMav
    GazMav Paid Member
    39
    Car:
    It's hard to explain but turn the hinged part 90 degree so the open part it facing down.
    Line up the straight bits and slide the hinged part over the lower part.
    Dont try to push the lower part into the top part.
  5. GazMav
    GazMav Paid Member
    39
    Car:
    I'm actually doing a manifold swap tomorrow night, I'll take a vid if you've not done your by then.
  6. Bro
    Bro Paid Member
    18
    Car:
    Clio 197
    I've given up for today and tried everything I could. Thought it would be as simple as sliding it in but it just wont fit. I'll give it another go tomorrow and see how it goes. Should've paid someone to do it :smiley:
  7. GazMav
    GazMav Paid Member
    39
    Car:
    It's easy when you know the trick honestly. It's not designed to slide away from each other.
  • Share This Page
