In that case tchalikias ill put money on it being the same as MentalPens problem
Its the clamp, by your feet, where the column meets the rack.
And too early? Some lad had his replaced at first service...12k!
Mine was done at just under 10k
And it was an easy fix? lol
What was the fix, Mentalpen?
Like the Mk2 meg it was a bolt on the rack, it should NOT be be tightened but over tightened and glued in place.
As soon as I demoed it the tech knew straight away what was wrong without even looking at it.
Was for me I had a latte and left them to it.
It had only been doing it for a few miles so hasn't caused any secondary issues. I think it's the fact that its not been done and they think the bolt is on correct which it is. But it is supposed to be over tightened and glued if it causes an issue.
Not knowing that seems to lead you been sent away saying its all ok, that then leads to more issues as it continues not being correct.
Thanks for the information.
I'm experiencing some different symptoms, which make me unsure that mine is a faulty steering rack. I'm going to have a FULL strip and check next week to clear that up. The car is otherwise absolutely mint, I just need to get this sorted!
Did Fred not find anything at all (saw your car in there a few weeks back)?
