squeaky seat...
... brought up a while ago but has ne 1 solved this yet, will get annoying when i travel from s.wales to fcs!!
ne advice
Does it sound like it's comming from the seat belt buckle?
You need to raise the seat as high as possible while sitting in the passenger seat then move the buckle backwards and forwards quiet sharply. If you get the same noise spray some silicone grease (or similar) as your moving the buckle near where it attaches to the car until the noise stops.
I've sprayed it once and so far no noises!
my recaros squeaked
check a thread a posted somewhere on here
took fabric off and foam (dead easy on recaro)
put smear of grease between seat 'bucket' and metal frame
found loose bolt on metal frame mounting to plastic bucket on right side bolster
need a 16 point spline to tighten
been 100% since. really pleased
