The Brembo discs are 313x28mm. I think there is no need to go bigger anyway, the Clio is not that heavy to make much use of it. The OEM items prove themselves relatively decent if abused on the track and they can block the wheels without a problem even if semislicks are fitted.
Bigger brakes mean more unsprung weight. So you have to compromise somewhere.
I will use DOT4 Brake Fluid from manufacturer "ATE" by the way.
