Thanks. I noticed that for the o/s shaft you've extended the shaft that I see on mine is the one between the diff and the drive shaft support bearing.
Have you swapped your shafts around?
No that's the outer shafts mate, the gearbox end half shaft is different, also has the rifled end that locates into the diff
_________________________________
GW 197 ex Michelin Road Cup Racer -> Track car/Sprints
http://www.clio197.net/threads/gw-197-ex-michelin-road-cup-racer-track-car-sprints.53560/
