Found on Ebay a stud kit which is actually for VW/Audi's but as it included a screw in stud and also the retainer bits, decided to order to see if I could fit, to stop the drivers mat from riding up under the pedals and jamming when pedals fully depressed.
I've just fitted them and all that is required is the removal of original plastic clips from the mats, just use flat bladed screw driver from underneath and they just pop apart
while mat is upside down you will need to use a sharp knife and open the hole up by approx. 2mm until the new lower clip fits into the hole and then pop the top part into it.
![IMG_0050.gif IMG_0050.gif](https://clio197.net/data/attachments/38/38892-76f9d58b976393b6f51a800cdd6085cc.jpg)
then they simply clip together
![IMG_0052.gif IMG_0052.gif](https://clio197.net/data/attachments/38/38893-76f9d58b976393b6f51a800cdd6085cc.jpg)
Now push the new screw in studs into the mat clips and go to the car and line up in side and once happy with position, simply push down on the surround and screw the stud into the carpet.
![IMG_0053.gif IMG_0053.gif](https://clio197.net/data/attachments/38/38894-76f9d58b976393b6f51a800cdd6085cc.jpg)
And that's it, you now have a secured mat which justs pops off when you want to remove it
![IMG_0055.gif IMG_0055.gif](https://clio197.net/data/attachments/38/38895-76f9d58b976393b6f51a800cdd6085cc.jpg)
The supplier on Ebay was Automotive Carpets
AUDI & VW STUD STYLE CAR MAT FIXING KIT (160497291142)
http://www.ebay.co.uk/itm/ws/eBayIS...42&ssPageName=ADME:L:OC:GB:1123#ht_2585wt_878
