Been to Ahvenisto race track which is located in Hameenlinna, Finland. Surprisingly, some tracks in Finland are nearer to me than the russian ones. And Ahvenisto is the lovely one, it has 32m elevation change, it is narrow and twisty. I've been here two times before and will defo return again.
Hameenlinna is approximately 500km from my home. First, I had an idea of using overnight ferry to Helsinki and then have an hour-long trip by the motorway, but found out that I can't manage to finish my work on Friday before the boarding ends.
I was a bit concerned about the first long trip on a Clio with my wife and 2y.o. daughter. But quickly found out that if you don't exceed 120km/h, the engine sound is not that loud, and even fuel consumption is relatively OK(not comparing to 1.5dci meg =)). So, the only thing I had to do is not to compete with random guys on the road, who defo want to overtake Clio RS )
And i totally disagree that stock suspension on 200 is too firm - the roads were very different, but we had no issues with it. I find it comfortable even for long trips. Seems that my daughter too )
Anyway, great track, great weather
great car
BTW, fitted new stock brake pads all around, changed the fluid - and brake pedal now feels much more trusty. It was like 15% of pads left on each axis.
Below are some videos. GPS works awful on that track, so I need to relocate the reciever somehow, probably under the windscreen. Currently, I had to remove the speed and track map overlays as the data is not relevant at all.
Later found a lap that was some .8 seconds faster, but it is much more clean and boring than videos above and I was too lazy to apply an overlay once again.
Actually, can't decide whether in-car camera works better than an outside one or not. Any thoughts?
Done 4 sessions total. Could have even more, but started to feel a bit tired which is dangerous on a track like this, so decided that it is quite enough.
