Hi all,
Happened for quite some time now, but every time I select reverse gear I get a clunk noise.
If i keep the clutch pressed and go into neutral and then into reverse again, it seems fine without any noise or problem. But as soon as I lift of the clutch pedal and try again into reverse i get the clunk sound again.
Tried with handbrake on and off.
Could this be something to-do with engine mounts? Or is it normal?
