Recaro Seats In Standard Clio
FINALLY got my hands on a full recaro interior that came straight out of an F1 clio 197. My question is will the seats or the runners need any modification to fit in my 2008 dynamique sx? The seats come with the bases on them already, but not sure about the floor runners.
as far as i know all the mk3 clio's are the same fixings for the seats.
the runners are all part of the subfame.
the only think that may cause you a problem are the airbags.
do your standard seats have side airbags.?
if yes you will still need a trip to the dealers for them to reprogram the airbag ecu, because recaro dont have the anti sub airbag that most seats do.
just make sure before working on the seats that you disconnect the battery for at least 20mins so the airbags dont go off.
ah! right. well i do have airbags in my seats at the moment, can image that might put a dampner on the evening if an airbag burst in my face, even if some people say it might be an improvement.
So disconnect battery, fit seats, reconnect battery then head to the stealers to get the airbag re-programmed?
cheers
