Rear View Mirror
matthewson
Hi Chaps,
Had a go at replacing my rear view mirror today as the glass on the current one was a bit scratched etc...
Was a bit forceful in removal, removed the surroundings for it, then pulled up instead of what I believe to be down to remove it.
When attempting to fit the replacement mirror it doesn't quite clip correctly. Is there a certain technique to get them on correctly or do I need to source a new bracket that the mirror slides on to?
If so does anyone know where to look for one?
Thanks,
Matt
I can't help with your question specifically other than to say you will be fine running no rear view mirror if needed, until you sort the issue.
All sorted now was being a big girl. Used some grips to help clip it back on! Might get a Laguna dimming mirror in the future...
