suj
Don't bash me for asking, but what's the purpose of adding shims if rear wheels have fixed alignment? Wouldn't that add more issues than it would solve? Correct me if I'm wrong, but if wheels cannot be aligned, then it means that rear wheels can't be out of alignment.
Anyway, I scheduled wheel alignment check this Monday. I'll let you guys know how it went.
Most things have been answered but I will expand.
So the rear axle is "fixed" in the sense you have no adjustment as it is, you cannot put "camber" adjustment on the top mounts or bottom, also if you did "move the rear frame" it could give you more negative toe let's say on the left wheel, the right wheel will get the opposite (positive toe).
It was designed around standard suspension, so as you lower it, it naturally cambers and toes (if you put load on a rear wheel, you'll see it in smaller effects).
The shim is an individual shim per side, where the stub axle meets the rear axle, as this is where the wheel then mounts to, this is what you are putting whatever combination of camber and toe shim to get your desired number. Then you do the the same process on the other side.
In an ideal world you would use the same shims left and right, but in reality it won't be the case (due to many factors, not lowered equally, warped axles, etc).
If what you said was correct, then you wouldn't ever have a need to have toe adjustment on the front or people wouldn't need camber adjustment.
Also it isn't just for track cars, people use shims on OEM cars due to what I explained about about wearing of components.
