Really Annoying Problem
Hi,
Has anyone experienced problems with their passenger side side light bulb?
I have lost count of the number of times I have changed it. Seems to need a new bulb every month! I wouldn't mind so much but it is a bit of a faff to change - what with removing the fuse box etc.
Is this a widespread fault or is it indicative of a fault in my car - possibly the wiring??
My last 2 LED's have gone on the passenger side (actually that reminds me, I need to change it)
It is a but more difficult to do than the drivers, however I don't have the remove anything other than the battery and fuse covers...... do you have sausage fingers?
Haha cheers for the replies lads - as to whether I have sausage fingers will have to ask the missus that?!?!
I can do the bulb change no problem - in fact the fact I have done it so many times it is a familiar procedure is what made me write the post!!!
My point is what is causing my car to go through so many bulbs? It is definitely specific to the wiring or conditions on the passenger side because I am using the same type of bulbs on the drivers side with no problems.
UPDATE - doubly wierd - the bulb appears to have fixed itself as it is working now!!!
Confused.com :001_huh:
faultyconnection.com :coffee:
if the connection isnt good and it keeps going on/off then that is going to shorten the bulbs life...
