question about pistons
hello. i have an renault clio mk3 200 2012 recently i damaged one of my pistons on my clio sport but before i rebuild the engine i wanna know if this is the original clio 200 engine because the piston numbers are different if someone can identify from which car this is from i would appreciate it since i cant find the engine block number eitherIMG_0596.png
On the mk3 it’s the letter that is of interest, you have B or C depending on your block bore (different from the factory), your block should be a 832.
I recommend taking measurements of the bore as they tend to taper depending on age/use which can then be made worse when honed (assuming you are)
Reactions: Marsch and Sean197
i appreciate it so much. what else do i have to look for to make sure its a F4R 832 block or head? i cant spot the block number at all so im trying to figure out if there’s another way to find out? and this is the set of cams i have no idea if its from a 832
Re the cams, the numbers don't mean anything, you need to measure the lobes to confirm but it will be standard if its from a mk3.
Reactions: Marsch
