Question about MOT and HID kit
Hello guys,I just have a quick one.
Basically my clio is a 14 plate and it will be due to MOT in April,the problem is that when I bought it,it was second hand (only had 4000 on clock) but the previous owner fitted an HID kit, unfortunatly I didn't ask him about MOT I just didn't think about it,he left the HID box in the car so I will be able to write the details if required,my question is will my clio pass MOT next month or 100% it won't?
thanks in advance.
I have xenon conversion in mine and it passed the mot. But I do know my moter and told him about it.
Is it hids into the standard reflector lights or is it a projector retrofit?
Yeah the reflector is the standard one he didn't change that,he only changed the actual lights and of course he fitted that square box one (sorry I don't know the english for it haha) for each light the make is Hids-Direct looks like is quite a good make.
Because Renault rang me today for my MOT but if you passed yours I will go for mine as well,thanks
Woah there, slow down!
Big difference - mine is a proper conversion with projectors installed in place of the reflectors. Yours are bright hid bulbs shoved into a standard refelctor light - a big no go.
First off, at the very least it should have a beam pattern - as halogen bulbs are designed to have this, where as xenon lights need the projector to have this beam pattern. Secondly as I said, I know my MOT'ers, Renault are a different kettle of fish as they do everything by the book. Xenons should be A) self levelling and B) have washers fitted...
Reactions: Hyde200
Ah ok I didn't know that,on the box it say that the light are h7r I don't know if that means anything?
Also where did you buy your projectors,can you pass me the link please?
They were custom built by a guy who used to be on here, not a cheap or simple job.
Have a look in my project thread and they are in there somewhere.
Ok,thanks a lot
But then sorry if they are custom made they won't be road legal anyway am I right?
Well hard to say - you probably have a very good light output now just at the cost of blinding other road users.
I'm still here
Haha I actually checked when I posted that and you hadn't been online in a long time! I know you use Renaultsport forums a lot.
Mine still are very good, although the flap still sticks on the right hand side with the xenon if on for too long...
Must of been a bad unit, you could disconnect the flap wire it if it is a problem. I'm now recommending a different (more expensive)unit, mine have been fine, done a few now, getting better at them [emoji854]
Would be handy to do that actually - how would I know which is the flap wire?
They are the very fine wires, I am sure a fitted a plug, possibly a Deans connector that just needs unplugged inside the light.
This is what I can see from the top of the light unit.
Need a better picture, the switched wire is possibly piggy backed onto the high beam wire, if you take a picture of that and also the other entrance hole as well, might give me a better reminder. These all evolve as I do them, I find easier ways or better ways to do things so they always get better and better.
