Quick question - MOT failure. Front springs broken.
Discussion in 'Suspension, Brakes & Steering' started by Webby, Oct 7, 2015.
  1. Webby
    Webby
    585
    Leamington Spa
    Car:
    GW 200 Mk3
    Hi guys,
    Just a quick question. My cars just failed it's MOT with broken front springs.
    I'm being quoted £452.40 for replacements which to me seems excessive. Am I right to think this?
    Also I can't get it out of my head that it's odd for both of them to have gone at the same time.
  2. chris mcm
    chris mcm
    380
    Belfast
    Car:
    RB 197 Cup
    Yes it's extremely dear considering you can buy new h&r or eibach springs for under £200. Good excuse to lower the car I think. Even if labour is included in that price you were given its still excessive.
  3. LJohns94
    LJohns94
    89
    Plymouth
    Car:
    Clio 197 F1 Liquid Yellow
    If thats just for new springs to be fitted thats quite steep! I got some H&R springs for £160 then got them all fitted for £155! so £315 all done! shop about mate!
    EDIT- this was for front and back by the way!
  4. Pav
    Pav Moderator
    11,611
    Manchester
    Car:
    albi blue 197 with boost
    i would opt for some upgraded springs..as above-Eibach or h&r are available from £100 second handed..fitting on top around £100...
  5. Joe.
    Joe.
    96
    Car:
    Clio 197
    If they are fitting genuine springs, aren't cup ones about £120 a piece so that's £240
    so £200 to fit them,
    If it was me (I was in this situation about a year ago) I would get some aftermarket ones, I got cooksports. and get all 4 replaced
  6. Jimmy
    Jimmy Good cop Administrator
    6,658
    Leeds, W Yorks
    What may have happened is that only one of the front springs has actually snapped - however it is 'best practice' to replace both at the same time. So perhaps the garage wants to replace both on that basis - but they should really clarify that with you if that is that case. I would ask them the question before going ahead.
    I was in the exact same situation as you recently in that mine failed the MOT because of one broken spring. The dealer advised me about it being best to replace both at the same time, however they gave me the option. Price-wise, it does seem excessive but I did pay a similar amount to that (I was in a situation where I needed the car back asap, so my hand was forced :001_huh:smile:. In hindsight I would have gone aftermarket and saved myself some money....
    Either way, I would first check with the garage/tester whether it is just the one that has snapped, or in fact both.
  7. chris1888-197
    chris1888-197 Paid Member
    828
    sunny glasgow
    Car:
    albi blue clio 197
    Hi pal, my car passed mot yesterday and I had a broken spring o/s/f so replaced them with cooksport springs I got from @roscoe on here. They sit really well just to add) I fitted them myself in work, is quite steep for a set of springs fitted, what type of springs is that for ? I know buying them from renault is pricey! Would def get all 4 done at the same time or at very least the 2 that are affected either front or rear as if you fit one the other will most prob be weaker and will prob go in the near future!.
  8. Jamz72
    Jamz72
    455
    Stratford Upon Avon
    Car:
    GW 200
    @Webby My front n/s spring broke last month and it cost me 2x £110 from Renault for genuine 200 cup springs and £170 fitting by Jade Development near Leicesters. So that's £390 all in! I was annoyed at having to spend so much tbh to fix a simple broken spring!
    I have my old spring for sale if you're interested (the one that wasn't broken) - it's a 200 cup spring so it has orange and blue identifier dots.
  9. montana
    montana
    1,166
    North West, UK
    Car:
    Deep Black 197
    Keen to know what steps you followed to remove the struts (lots of options seem to be available) ...
  10. chris1888-197
    828
    sunny glasgow
    Car:
    albi blue clio 197
    Hi [MENTION=52200]montana[/MENTION] I removed the wiper arms and then I removed the pinch bolts from the struts, the pinch bolts where very tight but a bit of persuasion and they moved. I then disconnected the steering column from under the drivers footwell .then I removed the track rod ends. I then put a transmission stand under the subframe and lower the subframe down about 20 inches enough to give the carriers a chap down of the struts then 3x 13 mm nuts on each side removes the strut from the car. We have a spring compressor in work to change spring the refitted in the same order. All in took about 3 hours. If you need to know anything else just let me know mate.
  11. montana
    montana
    1,166
    North West, UK
    Car:
    Deep Black 197
    Thanks, i tried and failed at the pinch bolts and got a garage to do it, however should i need to tackle in the future going to give it a go again, cheers :thumbup1:
  12. Webby
    Webby
    585
    Leamington Spa
    Car:
    GW 200 Mk3
    Thanks chaps,
    Yeah this is an annoying situation as the car had been on the ramp at Ren Coventry 2 months previously for drivers side hub and bearing. Cov claim that they would of noticed a broken spring then so to have both go in 2 months... :angry:
    Jimmy - your explanation seems the most logical answer.
    So I rang around for quotes yesterday and after Wolverhampton came in at £550 I decided that I'd just go ahead based on getting the car back today. NOT TO BE. Just had a phone call to say they can't get the parts for another 7-10 working days.
    Rang KTEC and they can get me the parts for £234 (4 Eibach springs). Local garage will fit everything for me for £260.
  13. chris1888-197
    828
    sunny glasgow
    Car:
    albi blue clio 197
    [MENTION=52200]montana[/MENTION] the pinch bolts were really tight so I just game them a very and I mean very slight heat as the hub carriers are alloy so wouldn't take much to weaken or melt! It was a bit more awkward than the normal springs / struts you would do but are not the worst.
  14. CallorFold
    CallorFold Platinum Member
    965
    Car:
    Clio 220 Trophy
  15. chris mcm
    chris mcm
    380
    Belfast
    Car:
    RB 197 Cup
    What [MENTION=52455]CallorFold[/MENTION] said
  16. Pav
    Pav Moderator
    11,611
    Manchester
    Car:
    very expensive ..£260 just to fit them??my mechanic did it for me for £80..wouldnt agree with that quote..
  17. Jimmy
    6,658
    Leeds, W Yorks
    [MENTION=1430]Webby[/MENTION] well the fact that they have quoted you 7-10 days at least allows you to shop around a bit instead of having your hand forced. There will spring sets out there for less, as CallorFold has linked you to.
  18. chris1888-197
    828
    sunny glasgow
    Car:
    albi blue clio 197
    Yeah I agree with everyone £260 is very expensive indeed. I would take nowhere near that to fit them to be honest! I would say £100 max for this job and if you shop about will get them fitted for roughly about that I would imagine.
  19. CKR86
    CKR86
    50
    Car:
    Clio RS200
    You don't wanna know how much KTEC charged me to fit Eibach springs all round then.
  20. Chris
    Chris Bad cop
    10,545
    Needham Market
    Car:
    LY 200t
    Lol i bet you paid through the nose!!!
  • Share This Page
