Pulling to the left
My car seems to pull to the left slighty. I took it in to my local quick fit today to check the tracking, they checked it and said it was spott on, what else could it be?
They all do it, 197s and 200s, I wouldn't worry.
It adds chracter!!! :smiley: Just drive everywhere on nice twisty roads and you won't notice it. :wink:
when i had the megane 225 wheels on and the 225/35 tyres mine drove arrow straight
now with the r26r wheels and 225/40 it pulls to the left slightly :worried:
try swapping your tyres/wheels around :thumbsup:
All cars are designed to pull to the left so u hit the rumble strip if you fall asleep
no its part of the steering aligment. straight is pulling to the left . . . not alot but enough to wake you up whe you fall to sleep
It's to do with the total geometry set up of the vehicle and the camber of the roads. My 197 used to do it, had it checked on a 4 wheel laser hunter rig and it was spot on. If I used to drive in the middle of the road it would be fine. Guys at work (Landrover chassis engineers) said nothing to worry about as a lot of hot hatches are set up as sensitive as this.
try driving on the opposite side of the road (assuming theres no traffic) and see if it still pulls left. Could just be road camber?
My does the same. I have had it laser tracked twice and had the wheels rebalanced several times but no change. It must be normal.
