oil catch can how to fit
Hello im thinking about buying oil catch(from ebay) can anyone share any pics how they fitted theirs also shoud i go for catch can whit breather filter or wtihout one?
It’s not quite as simple as bolting one on, as you’ll need the engine plate from somewhere like Pure to attach to the top of the rocker.
Its also a bit of a pointless mod really. Unless you’re fitting itbs?
It kinda looks cool and its not so expensive what about this video is this correct fitting?
Just fitted one this week myself.
Standard breather plate is fine. What made me fit it was I changed my inlets for some port matched ones and when removing the old inlets they were caked is oily crap all over the inside.
So I mounted a catch can in by the ABS pump, rocket breather into one connection and a pipe out from the other connection, vented to the atmosphere. Some silicone bungs for the pickups on the inlet manifold.
Reactions: ZorkoRS197
View attachment 142813View attachment 142814View attachment 142815
Looks cool thanks for share
Hi - for those who have fitted a catch can off the standard port of the back of the engine what size pipe have you used?
Hello ive decided to do a post after 3 mounts of catch can being fitted ive mounted it on the left side of engine bay whit simple made bracket ive used 3 post mishimoto clone catch can bought for 20€ ive blanked 1 input port on the second input port ive instaled silicone hose to the rocker cover where pcv valve was connected and on output port there is breather filter after 3 mouths of driving the car these was inside the catch can so it definetely it does work130820020_815399335905880_6007103618789699384_n.jpg206211956_5725480510856429_9075538050383916283_n.jpg212555389_893861164499654_4575156271936513295_n.jpg209327646_207133121298677_8625116354851910610_n.jpg
Do you know where you got the silicone bungs from and what size to use?
The PMS breather plate doesn’t fit with the standard inlet unless you machine down the TB and the plate itself. Best off sticking with the OE breather and either using push on hose or weld on an AN10 fitting.
Can some one please tell me how to install an Oil Catch Can on a Renault Clio 2 Please 16V, I really need help with instructions on this.
