Hi guys. I am having an issue with my 197, where the car will not accelerate properly sometimes, and is really down on power. I had a fault coder for knock sensor so I changed that anyway, but I've also recently changed the plugs and coils as well as the cam sensor but none of this has cured it. If I turn the engine off and then back on again, it will be ok again for a while. The only other idea I had is the thermostat or coolant temp sensor being buggered and the car running on the cold settings?
Has anyone else come across this and can help?
