M
Mentalpen
Got this for the kids!
Piston assembly
Fitting onto the crankshaft
Sump pan build
Piston/crankshaft & cylinder block onto lower crankcase
Valve assembly
Fitting valves to lower cylinder head
Rockers next onto upper cylinder head
Gasket & cylinder block with camshaft in place (missed the pic sorry)
Timing next with tool in place
Water pump fitted
Fan/Pulley/belt & flywheel
Distributor on and ignition timed
Plug order 2,4,3,1 & exhaust manifold
Throttle body / inlet manifold
Job done
Piston assembly
Sump pan build
Valve assembly
Water pump fitted
Job done
