My 200 entered into Vertar's car of the month comp!
This month my car is entered in Vertar's Car Of The Month competition. I would really appreciate your votes, a lot of time went into this car when I got it. The first detail took me approx 14 hours, although I did have some visitors from the Yorkshire posse so that did stretch it out a little.
Just some info on the detail.
I started by asking the dealer not to clean the car, so on 1st sept I picked up my brand new and quite dirty Clio 200.
As it had never been cleaned I wanted to make sure that I got as much of the muck and grit off as possible So to start with it was snow foamed and rinsed 3 times.
Next was a wash, 2 buckets, gritgards etc followed by a rinse.
Then clayed with Zymol Lehm Clay and lube.
Then machined using Swisswax Cleaner fluid pro. This stage cleans the paint, does a very minor correction and fills a lot of the swirls/marring etc. Any place I could not get the machine easily was cleaned with Zymol HD Cleanse which does a similar job but by hand.
Next on to the wax - Zymol Concours - wax on wax off etc
Then on to wheels.
Cleaned using Zymol Wheel Cleaner with Zymols horsehair brush.
Clayed
Cleansed using Zymol HD Cleansed then waxed with concours
Tyres dressed with Maguire's tyre gel.
That just about covers it. Like I said all votes for my car will be very much appreciated.
Just to add Vertar give you a £5 off voucher for each vote!!
http://www.vertar.com/car-of-the-month/renault-clio-757.htm
Main one, would be nice just if it was mentioned. Technically I could ask them to remove it but it's nice to be credited at least given I turn up to these things with several £k worth of kit to take photos ( admittedly for other people but still ).
p.s I say £k's but that photo was taken with a £80 lense :tongueout:
Look I could not remember for definite it was you,
You can ask Foxspeed and F1Team07, I have discussed with them about a thank you to you.
PM me if you want!!
If you didn't know that's fine, just pointing out it's one I took and that it'd be good to be thanked. Good luck though I voted just because of the picture :tongueout:
No offence intended at all. I was pretty sure it was you but just not 100% Dint want to make a mistake.
Its a cracking pic, easily the best(by a country mile) of this car.
You should come on a run or to the monthly meet.
Its only a junction or 2 up the road from Donny!
I had planned to join up on saturday but I have a visitor, will try my best to come (my car may be filthy though).
