What are the most common leaks from the lower half of the engine? Rear main seal, oil pan seal, gearbox input shaft, drive shafts or clutch slave cylinder? I'm trying to locate a leak which seems to come from the rear of the engine, but I'm having trouble. I'm thinking RMS since oil is dripping out from the split between the bellhousing and the rear of the oil pan.
