Hi guys! I own a clio from 2007 and there is a problem I can’t solve. Under half throttle from 2500 to 2800 rpm the car goes wild, it feels like misfire or fuel cut, but after 3000 it pulls normal. I’ve changed a lot of things, spark plugs, coil packs, MAP sensor, camshaft and crankshaft sensors, timing belt with dephaser pulley is new as well (VVT solenoid is working), second lambda. Also there are no air leaks, and no error codes on can clip.
Any ideas what can cause this? It drives me crazy that i can’t find what the problem could be.
