Morning chaps,
I have got a metallic grinding noise when I am turning right and about 3-4k RPM. When you are going under 5mph one of the wheels seems to be squeaking as well...
I have had this noise before but it was the gear box (was like it when I purchased from the dealer) This was the explanation from the guy who changed it at the dealers:
I have since had this gear box replaced after the fatal crunching in April of this year which Renault contributed 90% towards.
After searches around the internet I have come to the following conclusions and what my options are:
1) Check the break pads / calipers on the front in case of rubbing or seized pads. I am going to check this at the weekend as I have new pad and pins for the front anyway and need a service.
2) Wheel bearings have gone which would mean a new hub?
3) Gear box has gone again in which case its back to Renault and gear box number 4...
Has anybody got any opinions on what it could be? I will see if i can get a recording of the noise.
Hard to explain really! Its not the typical noise we get from them, normally the synchro's **** up lol.. But with yours its more related to the Dif area.. Obv after corning it stabilises and during that process your noise appears, sometimes its really bad.. It does do it when going along aswell but its not as noisy and noticable.
