I have posted in the Engine and Gearbox forum as well but thought i’d post in here in case anyone who’s done these conversions can help out.
I’ve fitted the Airtec radiator in my Meglio, and originally the fan was just wired on a switch but i’ve found the original fan wiring so was hoping to use that. So checked the power to it and found as soon as the car is started up there’s 12v present?
I’ve then plugged in my snap on scanner and read the coolant temp which is only 12 degrees, but the fan request is active as soon as the engine is started?
Surely this is an input to the ecu somewhere to tell it to put the fans on? Anyone else had this at all? I personally haven’t done the conversion so don’t know what wiring has been done?
Enclosed pictures of the screenshot from the scanner with ignition on and then engine running.
