tombate911
			Hi everyone. Not often I come asking for help here so hopefully this goes well!
Looking a starting wiring for my 225 Engine. I do however have a PH1 loom that i'm hoping that I can modify to work with the R26 ECU and the Clio.
I've had a good read through the following thread... However it appears the plugs are different
http://www.clio197.net/threads/rough-guide-megane-225-230-engine-conversion.19912/
Some people have been telling me that the PH1 loom isn't the one to use, but can it be used with modification? I've also been told that I should just use the Clio loom and add into it what is needed to run the Megane engine. Guessing just the boost control solenoid wiring and the 2x MAP sensors in the boost hoses? In my eyes I would only be adding a few wires to the Clio loom and wouldn't have to go around depinning everything like the meg loom requires? Unless the ECU's use a different pin out between Clio/Meg.
This is the fuse box part of the loom I have to modify. The plugs here don't appear to resemble the ones in the drawings in the threads posted above. Hopefully someone has some good information on here regarding wiring. I'm thinking @Stephenvenning @DannyAG200
