Like DS said, you need the discs too as the pads are a different shape to accommodate for the 340mm discs (I think that was the Meg size).
You need to re-drill the standard megane discs IIRC.
It might be easier spacing the standard calipers and using 330mm discs that people normally do.
But I still think standard calipers + good fluid + some good brake pads will be plenty, many people on here have ran them for years with no problems (then you can get brake ducts to aid with the cooling) it will be as good and less of a faff.
