nutnutwelshman
Gold Member
could do with the airbox layout/diagram. anyone know where we can get one?
using pipercross panel filter, think the only other panel filter available is bmc. as for induction kits, the 250/265 setup is better than the 225/230 setup, few people have had there cars used in development for an induction kit, one was itg, and they couldnt get no gains. best to do is fit panel filter, and remove the insulation out of the box. ive also heard the 250s have a resonator box behind the drivers headlight somewhere, then they later took it off for the 265 how true it is i dont know. something i may look into about removing.
its suppose to be hiden under the fuse box behind/under the drivers headlight, someone on meganesport.net hads his bumper off on a 265 (trophy or normal 265 i dont know) and noticed there wasnt one, and when he enquired about it at renault, the 250s suppose to have it and recon the 265 didnt have it, maybe this is why the 265 is suppose to be louder
Team Clio197.net to the Megane technical rescue!
I did the fitting Clio Recaros to the Meg guide so im off the hook and now if Ryan solves this.... what are you going to contribute Mentalpen?
Any other benefits other than slightly better noise?
