KW V1 vs H&R coilovers
sir_dave
With the collection of my 197 cup around the corner, i am now looking into potential ways to perfect it ...
I understand that the H&R's are a little firmer (potentially better on track) and offer scope for a lower ride height at the rear, but the KW V1's are less firmly damped for a more compliant ride on the road ... They are also £150 or so cheaper, which would pay for the Ultra Racing rear ARB that will also be fitted at the same time.
My interest is from a handling perspective really, whilst an improvement in looks via lowering of say -20mm is nice, i am more interested in obtaining a similar handling balance to that of my Trophy, i.e. strong front end bite, with a tendency for oversteer when on/approachng the limit of adhesion.
Damper adjustment is not really something that i am interested in paying extra for really, i also found the additional of the Whiteline ARB to the Trophy added the additional rear end stiffness that i was after.
Alternatively, does someone like Bilstein/Koni offer a damper only solution for the 197, that could potentially be partnered with some of the H&R springs?
Your thoughts? :smile:
I had the kw1s and thought they were a definate improvement on road n track over 200 cup suspension.
Personally though i would lower the front 25mm and rear no more than 15mm. Otherwise large bumps/potholes can cause some minor grief. I had 30mm front n 20mm (max on rear) and felt raising that 5mm would have made it even better.
Also the kws dont rust at all 8)
I haven't driven a trophy to be honest with you mate but for a second I thought you were describing a stock 197 there:tongue_smilie:
I did some research for the suspension and personally (and for the way I use my car of course) I can not justify paying so much money for a coil over. Renault has done a fantastic job setting up the car so for me a RARB, a thicker fARB (from the 200 cup, 19mm) and a set of H&Rs 30mm all around will do the job. To be honest I'm so happy with how the car handles that I'm a bit reluctant to even change the springs. I don't even know what their rate is (popped a question in the past but no one knows apparently). I just hope that they won't ruin the handling because if they do i'm so removing them. Looks are good, but not that good (to me anyway). :smile:
If you go for the H&Rs I would recommend protecting them with some sealant as they do rust when untreated. I treated my set but they still corroded slightly.
I, like Daz, moved up to the Clubsports now but I'd recommend a practical ride height. I didnt go too low as I (More so the wife didnt't) want to have to drive everywhere worrying about scraping.
My ride height:
Also, on track do you intend on using semi slicks (R888s or similar) as even the H&Rs aint quite stiff enough to eradicate some major nose diving on hard breaking, turn in etc.
Just look at Simo's progress thread for pics.
Wouldnt be using R888's no, i found that they simply made things too easy in the Trophy. Quicker yes, but more fun? Not especially, clio doesnt have enough power to warrant them i dont think. Nose diving isnt an issue that id want to erradicate completely anyways (unless its ridiculous) - purely as the weight transfer helps with front end bite!
I do like your ride height though, although i would perhaps have it a little higher at the rear to keep the standard rake.
Did the H&R's rust badly then? Its more than likely that i'll only keep the car a year or so, so would like the coilovers to stay in decent enough condition to sell on at the end of my ownership ...
I wouldnt say badly no. But I did protect them with some metal sealant/treatment from day one (Spray stuff on and rub in once).
I sold them to Jonesy on here and he had no complaints as to how they were when they arrived.
