I thought it was time for a little update on the thread as I haven't done much for a while - mainly because there wasn't much to report...
First off, as I mentioned earlier in the thread, when I was having the lower ball joint replaced at Bolsover Car Care, the techs noticed that the steering rack arms and bush needed replacing as they had play and it was a potential MOT failure. So i booked back in at BCC and these were sorted out by the very helpful Mark Black and his colleagues. These little jobs, although not massively expensive, meant that I had to put on hold some other plans I had for no.243. More on that later...
This week, I've had a busy couple of days getting some things sorted that needed attention. First off, the front nose grilles had faded badly and they were looking frankly horrible... It was only when I saw what they should look like that I realised they needed sorting asap.
How they looked before:
So following some advice and guides from the forum, I cleaned them up and dried them off and gave them a couple of layers of primer:
Then I sprayed them up using Satin black paint, giving them a few thin layers to build up the paint.
I was really happy with the end result and how easy the whole process is. I was a bit nervous when I first pulled the grilles off the car, but they come out with a bit of gentle force
It is such a massive improvement over what they looked like before. And here they are back on the car:
Next up was replacing the very perished three-quarter window seals. They were quite easy to take out and removing the old glue wasn't too tough either. Just needed to spend a bit of time scraping it all off to make sure the surface was clean for the new seals to go on. The knackered old ones:
Putting the new ones on was also very straightforward. It's just important to be quick making any adjustments as the glue takes hold pretty quickly. I then used a credit card down the back of the seal to press the glue up against the glass. Looks a lot better and although I hadn't noticed any water/moisture in the door shuts, this should make sure that it definitely doesn't happen.
Finally, another cosmetic change, and that was to 'de-tango' the front and rear indicators
I bought some Silvatec bulbs from eBay and the swap over is very easy too, at both ends. It also gave me the opportunity to clean up behind the rear light clusters. With the silver bulbs in, I think it makes such a big difference to the front end, it cleans it up a huge amount and looks a lot better. With the re-painted grilles as well, the front of the car has had a bit of a refresh
And they tidy up the rear clusters well too:
So all in all, some small changes have made a big difference to the car imo and I'm happier with the way it looks. Having said that, there are still a couple of areas that need attention...
The wheels are in dire need of a refurb. They have started to corrode in places on the spokes and along with some old scuffs and kerbing, they are far from their best :bored: a place has been recommended to me in Bradford that can refurb wheels to a good standard and they charge by the inch. So quite reasonable really. The downside though is that the process takes 3 days and they need the wheel with the tyre taken off...
As I use the car as a daily, the above is not the ideal scenario... So I am toying with the idea of finding some temporary spare wheels, or just paying more to get the refurb done elsewhere and therefore quicker... A dilemma!
The other thing that needs doing is the painting of the wheel hubs. I should have done this when I got my new brake discs fitted and now they are all rusted, which along with the gammy alloys, makes for a bit of an unattractive sight around the wheels
this is something I will be doing in the very near future though.
Lastly, the service and MOT is due next month, at which time I'll also get the brakes stripped and cleaned, the gearbox oil changed and the air-con recharged. This will be done at Harratts in Pontefract, who are a great dealer for anyone in the West/South Yorks area who is interested in a main dealer option.
Thanks for reading, C&Cs welcome
