Is this an oil leak from a bad gasket? Or overfill? (Pics inside)
With 18 of the aluminum screws/bolts removed (including the big ones that connect to the subframe bushing), I thought I was ready to remove the oil pan.
Then I discovered these- question is, are these even removable or are they rounded off? I couldn’t get a grip on them.
I’ve got a nut extractor tool set on the way but I have no idea how it’s going to grip as there’s nothing to grip on to?
I go along with that it should be the same as the rest of the vertical bolts external torx get a good set of sockets not cheap ones or you will damage the bolt heads and it's very easy to use a socket one size too large.
Reactions: Kalamat88
You guys are right- they were the same exact screws. Got them out with a 1/4 socket and found an extension that just barely reached it. Here’s the aftermath:
Do yall reckon I can take some cleaner on this while I have the oil pan out? I see there’s this plastic thing that I don’t want to use anything too harsh. This is the first and probably the last time I take this sucker off so I do want to make sure everything is spic ‘n span.
Only one bolt (top right of pic) if you want to remove, use brake cleaner (not water) and tbh it’s a pain to clean and probably not worth it.
FYI there is a sequence to torquing the sump back on if you haven’t seen it already.
You need to use the correct socket when you refit the sump!!!
RSRowe- most certainly! Haha I’m going to be extremely careful. I’ve ordered some new bolts for the others that were stripped to hell.
Liam- yes, thank you. I have seen this but now I have it handy in this thread, I appreciate it.
I knew there were particular torque specs but not in a certain order.
Yes, brake cleaner was what I had in mind so now I’ll be sure to give it a good dousing since you recommend it.
Thanks again fellas for the support and guidance
