I've recently purchased a Clio 200 with powerflex upper engine mount insert fitted. As others here have discussed, the vibrations from it are a bit uncivilised and I'd rather go back to stock. Obviously since I didn't fit it, I don't have fitting instructions and have spent a lot of time trying to find out the OEM part to replace it. I've now come to the conclusion that it may be additive only - i.e. I can remove it and the remaining mount will be functionally complete.
Does anyone here know? I'd imagine some of you fitted it yourself and would know well. Also, if I'm right, is there a torque value that the bolt needs to be tightened to?
Go easy on me, I know what a lot of the words above mean without necessarily having a clue what I'm talking about!
