How to remove interior rear plastic bits?
Jamz72
Basically I want to remove the two bits of carpet each side of the boot, to do this I need to remove the plastic panels in the two pics below. I don't want to yank them the wrong way and break off any plastic clips!
I have removed the two bolts and popped up the two bits on the top. I think there are two clips inwards of the bolts and also underneath the plastic bits that are popped up but I don't know how to get it off.. any advice?
Here I have popped the plastic bit on the left but it hasn't done anything and I don't know what to do with it?!
Those bits of carpet just pulled off in my Cup. I prised them off from the under the parcel shelf trim, then around the rubber seal, they were just tucked under the boot trim and slid out?
Hmm I may be able to pull them out but I would rather take the plastic trim off to make it easier. Especially as I'll need to re-fit them afterwards and I can imagine it will be a lot harder re-fitting with the plastics in place than taking them out
