As above. Remove not then just pull? Right one came off with ease left is being a bitch!
N0ddie Platinum Member Feb 11, 2012 #1 As above. Remove not then just pull? Right one came off with ease left is being a bitch!
Jonesy Feb 11, 2012 #2 u have to lift the actual arm abit so its inline with the knuckle and then pull up in one go, if hat makes sense Last edited: Feb 11, 2012
MikeDX Feb 11, 2012 #3 on mine i had to stop the wipers in the 'up' position rather than down to get the bugger off because it wouldnt lift up past the bonnet!
N0ddie Platinum Member Feb 11, 2012 #4 Managed it. Passenger side one was a bitch but the drivers on just came off easily. Cheers guys.
N0ddie Platinum Member Feb 11, 2012 #6 I put plenty of grease on the splines so that next time they will come off a lot easier.
Arran I Love Lamp Platinum Member Feb 14, 2012 #8 My dad taught me a trick with these, leave the bolt on a couple of threads, so when it pulls off you don't fall back and scratch the bonnet.
