Horn help!
Had my right stalk control out , trying to fix my window wiper fault and now after putting the right stalk back in and all connectors securely in place my horn no longer works , is there anything on the right stalk / connectors that do the horn ? Fuse is fine!
not normally it works via the steering wheel centre push
have another look in case you have dislodged a multi-plug on the steering column
