so odd occasion Ive got in the car and figured I’d caught the hazard light switch... fast forward to today, found my scuttle panel full of goldfish (not really but it could have supported a few!) and carpets inside a bit damp, when I first picked up the car the rear windows misted like a good un strangely, figured out why I reckon, I suspect I have some moisture in my uch, worth a check for bizarre behaviour, don’t think it’s the hazard switch for one second, I drained the scuttle to a degree, but I will be removing the plastic panel and cutting the grommets down to an inch or so long so they don’t get blocked up! And also whipping the uch out and giving it a thorough drying to reduce chances of damage occurring down the line due to corrosion! Windscreen wiper motor was also under water to a degree, but I reckon that’s designed to take a bit of moisture from where it’s fitted!
