Phenom
So i changed my rear discs due to a failed bearing, took everything off, wound back the piston to fit over newer disc.
there was nothing in the handbrake would do 20+ clicks with no resistance, so got to the adjuster and now it has 4 clicks of nothing and then the fifth click is like a brickwall.
there is no movement in the cable or in the mechanism on the caliper either. i've given the handbrake mechanism a couple of taps each side to see if it would free up and nothing.
you can feel it in the caliper (like a small tap) when you pull the handbrake up but no movement on cable or caliper.
any ideas?
thanks in advance
any ideas?
thanks in advance
