Used the dremel to cut the collar off the torque arm whilst it was out of the engine bay, quite straight forward.
Installing the mount in to the arm was a doddle too.
What are these vibrations that everyone complains about? I only noticed a SLIGHT and I mean SLIGHT (only because I was expecting them) increase in vibrations. The car does a little thump starting and stopping the engine but really that's about it...?
On another note, tried to rock the engine myself by pulling it and it just simply DOES NOT MOVE at all. Way better in my eyes with very little increase in discomfort.
Haha - YES.
If you ratchet strap ***something*** onto a Transit Van bed and then try to move it to check if its secured down properly: the whole van will rock.
THAT's what the firmness of the uprated mounts remind me of when i try to rock my engine !
Yeah I dremeled that bloody collar off the oem top arm too, I'm sure I've read of people saying easy just bend it - fair enough if Geoff Capes is your neighbour I guess.
oh and if doing to protect flexi's I think the lower one has more impact than the upper. A little bit of speculation on my part but I've seen a number of cars without a top arm at all when running the full vibra kit, and of course vibra don't make a top one - maybe failed logic but seems reasonable to me. Personally I run a powerflex top arm and the full vibra kit, but if you change any more i'd go lower first.
Jeepers man I had to yank the wrench for it to clickYep just double checked in the service manual & both bolts for the top arm are 105nm.
Very nice one too !
What filter / induction / airbox set-up you running ?
It's the KTEC Induction Kit, it's fantastic and improved my throttle response down low (until I ruined that by putting a straight through exhaust on it!). There's little to no heat soak with it too. After a hard drive, you can feel the cone is cold and half the pipe is cold too so it's doing a very good job.
Interesting !
And sounds really good (No pun intended), like its doing a 'proper job'.
Cheers.
Yes it was fantastic. Only made a noise past half throttle and the growl down low sounds like a subaru.Could you live with it before the exhaust got ASBO?
Sent from my iPad using Tapatalk
Gordini Seat Plug - Help! | Interior and Audio | 19 | |
White 200 EDC Gordano services | Spotted | 1 | |
| J | Clio 200 at Gordano & LY 200 M5 | Spotted | 1 |
