Gearbox Change
matthewson
Hi chaps,
Will shortly need my gearbox replacing due to a nice crunch into 3rd.
I have picked up what I believe to be a revised gearbox (TL4S20) with 4k miles on it.
I'm going to replace the clutch and slave cylinder whilst I'm at it.
Is there anything else worth replacing/upgrading whilst this is being done?
Thanks,
Matt
Look at the slave cylinder as mine cost me a fortune a few weeks ago as it pissed fluid onto the clutch. Only 62000 miles as well. (£1184 bill hasn't helped my month)
If you already have the parts it's a easy job it's about 4 hours first time as there will be sized bolts if not that's a bonus don't forget gear oil slave and cluch and brake fluid
Sounds a little more than 4 hours from what I've read so far!! Good call on the fluid. Have box fluid and think I have some brake fluid laying around as well!
Def not mate I do no problem in 4 hous even if they have been not looked after if you do more than 5 hours your being ripped off your prob better doing it yourself if you are able to or go to a specialist
Pretty sure the Renault book time is around 6/7 hours for the removal and refitting so could easily be done in less :smile:
Are there any specialist tools needed for this?
Two Techs are only about 40 mins away so will give them a call and get a quote.
I have a Toyosports manifold sitting in the spare room and a set of Powerflex engine mount inserts, would this be a good time to get them fitted to save on labour costs?
Nothing more specialist than any good technician/mechanic wouldn't already have.
You need to drop the subframe to fit the manifold so I guess it would be a good time to get it all fitted at once.
Terry did mine for me. Off the top of my head, It was about £600 in all, that included dropping and replacing the gearbox, changing the clutch and swapping the exhaust mani, plus oil etc.
I always take my car there, great guys. Highly recommended.
I changed to the Redline stuff and if anything it seemed to make the changes worse! I then changed to the 'new' Renault stuff (Elf Tranself NFJ 75W80) and it seemed to get a bit better..
I've seen you post that a couple of times fella, wht do you recommend? The Redline stuff? I'm changing mine in the next month.
plenty of choice on opie oils site....one of the things I did on mine and gearbox was fine..in fact it had 2 oil changes whilst I had it
I got/used some either Castrol or Valvoline fully synthetic been awhile so not sure exactly which one (from local motor factors)
