Frayed flexi pipe
I discovered a blow in my exhaust/ manifold and took a look this evening! Anyway I found that the Flexi pipe was frayed pretty bad, I guess this is the problem. What options do I now have in terms of fixing it
any help would be much appreciated
I bought those ones. Although they're not exactly the same, they will fit on fine if you're good with a grinder and a welder. If not, an exhaust centre or fabrication company will sort you out.
