The problem is the fire will probably be front end or in sideI want to mount one in the boot but not sure where to mount it. I never have much in the boot so open to ideas even if its on the boot floor. Anyone found any existing holes or mount points to save drilling?
A lot of fires are started at battery or main power cables. If your extinguisher is in the boot and the power is killed your boot won't open.
Also, an I correct in saying a 197 boot can't be opened if car is running?
Bolt it to the floor in the passenger footwell, half tucked under front of the seat. Use big washers or flat plate under the floor so the bolts can't pull through. Get a good quality, good size motorsport extinguisher and
It will have decent clamps. I'll get some pics up tomorrow.
Made a bracket that fits to the passenger seat front 2 fixings
Easy to get at from the drivers seat
We went for a 1.75kg foam extinguisher - http://www.demon-tweeks.co.uk/motor...lifeline-hand-held-fire-extinguisher-1-75-ltr
Got any pics mate?
Just click the Demon Tweeks link in the post above buddy
Marginally off topic, but if the keycard is in the console slot the boot can be opened with the engine running.
may not open, if it is a electrical fire could fry something boot release related before you realise what has happened
