Yiannis197
ok bear with me with this one please....
I was driving the other day and while i was stopped at a traffic light the revs went up to 3k and stayed there for a couple of seconds. Before I think wtf etc the car went into limp mode, the stop and spanner indications went on and an error message read ''Injector Failed''.
I knew enough not to start panicking so I pulled over, I switched the engine off and then back on again BOOM no problems. As if nothing happened, the car was as it used to etc. No problems with that. Here I would like to mention that sometimes when the engine is cold and I blip on the throttle the revs go up to 2-3k and stay there so I have to engage a gear and lift the clutch slightly so as to drop them. This last about 10-15secs and then the car behaves normally which makes me think that the TB is on his way out? Just a guess but it's happening more and more often...
Anyhow, today I decided to take the car to my local mate/mechanic and plug the diagnostics pc in. The error that came up was ''Pedal Sensor Circuit Incoherence''. Again, I wasn't bothered because I thought that this had to do with the Sprintbooster.
However, and this is where the true problem lies, when my mate was messing about with the throttle and the revs etc we realised that at about over 2k rpm the car has a vibration. A quite noticeable one I might add. I've never noticed it and I really don't know when this started occurring because obviously I don't take the revs up to 2k and hold them there. I can not feel anything when driving, it only occurs when the car is stopped and the revs and 2k.
Moreover the guy told me (after listening to the engine with a thing similar to what doctors have, don't know the name of it) that the engine does not operate as smoothly as it gets and that every now and then it kind of kicks/knocks. Now this is difficult to explain but what I did was to place a glass of water on it when the engine is on. Here is a video.
https://www.youtube.com/watch?v=-uCOcedMZ7U
You can see that the pattern of the glass/water movement is not the same. (@5th second is quite clear and towards the end).
Now my question is what could cause this vibration? Would a bad cam timing do such a thing? Engine mounts? The top stabiliser has been replaced as well as the lower mount. Are these two things (or three if you include the error fault) connected somehow?
Sorry for the essay, any help greatly appreciated.
