Engine mounts
I am wanting to replace all my engine mounts, don't want to go powerflex before anyone says so. Please can anyone confirm if these are correct in the image below. I believe it is the bottom one which lists 3x mounts which would then leave me to get the top stabiliser bar.
That looks correct -
I believe 33206 is the gearbox mount, 34264 is the upper engine mount, 29586 is the lower engine/dog bone mount. So you'd just need the top stabilizer :smile:
Brilliant thank you very much. Do you happen to know where I could get the torque settings for these when fitting them?
