Mounts, shafts, exhaust manifold, wiring/ecu, and usual bits like rad and fuel hoses. Speak to Mitch at Proline Motorsport (has a race build thread on here), he's very capable to do this.
The engine and box fit's in the bay really well:
Mounts you can use the top of billet Kswap mounts, you just need to weld up the steel cradle on the legs:
Gear shift is easy, use the Ktuned no-cut shifter. Uses OEM Honda cables from shifter to box. I have a set of OEM Honda cables too included:
I've got OEM Honda driveshafts, you can cut them and the Renault ones to fabricate the correct length, then new single piece shafts can be made using the measurements.
Engine includes aircon pump (probably ditch that on race car), alternator etc, also the full engine wiring loom. Probably use a DTA and Stack dials would be the easiest, but you could use the SC Renault p'n'p ECU but rather than pick up the F4R engine side, just use the K20. Chassis and CANbus side all remains as-is and retain full dash and dials etc.
The engine was a K20Z4 from a FN2, 29k miles.
The box was from an FN2, 2011 plate so has the LSD.
I paid, £1690 for engine (with all accessories), shafts and gear cables. £700 for the box.
Would do a deal on both.
Having already spent 5 figures on my engine and box, I simply hit a point where I woke up and thought ****, have I really spent this on a Clio and about to commit to considerable further expense on it! Hence doing a rebuild of what I've got and selling the K20 to fund it. - Have a word with Mitch and get some ballpark pricing then let me know, but compared to a proper ITB'd forged build on an F4R along with sticking a Diff in the Renault box - you'll be at conversion money. K20 will have a huge performance ceiling compared to the Renault and be far more reliable doing it. But if you've already had K20 then you'll be better placed to know I'm sure
It'll be going on eBay this weekend, probably Sun eve.
