Electrical non-starting issue - few weird things
The spare UPC I got from a running 197 has a part number 674661B so that was never going to work - so glad that's cleared up
I just checked the part number using the reader and the part number is the same as above :smile: - so get another UPC and hopefully fix the issue before i look at changing the loom
thanks again for the help - owe you a beer if I every bump into you
OK so you can communicate with the UPC the vin number CRK8 points to Clio 3 RS late model so it's a Clio RS UPC my parts lookup only goes up to 2011 so at this stage make sure you can with the diagnostic talk to all the computers when the ignition is on that will check they are powered up and the CanBus network is working between them in red the other two might not be on your car.
Reactions: Sean.R and Sean197
So the new (2nd hand) UPC arrived. The correct part number this time.
Checked to make sure it had the same relay and fuses fitted
Plugged it in and imob light back on
Had a play around with the diag tool and copied my VIN number over
Switched off etc
Back on and still this imob light won't go out
Checked the details of the module and now shows exactly the same as the original
So maybe this is pointing to a wiring issue rather than the UPC
I have a mate coming over with his CLIP next week to plug that in and see if we get anything
But of a kick in the stones but the show will go on
However I have had some success
Sorted out the wiring for the gauges
Added oil temperature
And moved the fuel.pressure down to sit with the wideband gauge
Love a Stack gauge - timeless
